spanning-tree
Displays spanning tree utilization
information
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
show spanning-tree mst {configuration|detail|instance|on}
show spanning-tree mst {configuration} {(on <DEVICE-NAME>)}
show spanning-tree mst {detail} {interface|on}
show spanning-tree mst {detail} interface {<INTERFACE-NAME>|ge <1-4>|me1|
port-channel <1-2>|pppoe1|vlan <1-4094>|wwan1} {(on <DEVICE-NAME>)}
show spanning-tree mst {instance <1-15>} {interface <INTERFACE-NAME>}
Parameters
spanning-tree |
Displays spanning tree utilization information |
mst |
Displays Multiple Spanning Tree (MST) related information |
configuration {on <DEVICE-NAME>} |
Optional. Displays MST configuration
- on <DEVICE-NAME>
– Optional. Displays MST configuration on a specified device
- <DEVICE-NAME> – Specify the name of the AP,wireless
controller, or service platform.
spanning-tree |
Displays spanning tree information |
mst |
Displays MST configuration |
detail |
Optional. Displays detailed MST configuration, based on the parameters
passed |
interface [<INTERFACE>| age <1-4>|me1| port-channel
<1-2>| pppoe1| vlan <1-4094> wwan1] |
Displays detailed MST configuration for a specified interface
- <INTERFACE> –
Displays detailed MST configuration for a specified interface. Specify
the interface name.
- age <1-4> –
Displays GigabitEthernet interface MST configuration
- <1-4> –
Select the GigabitEthernet interface index from 1 - 4.
- me1 – Displays
FastEthernet interface MST configuration
- port-channel –
Displays port channel interface MST configuration
- <1-2> –
Select the port channel interface index from 1 - 2.
- pppoe1 – Displays PPP
over Ethernet interface MST configuration
- vlan – Displays VLAN
- <1-4094> –
Select the SVI VLAN ID from 1 - 4094.
- wwan1 – Displays
Wireless WAN interface MST configuration
on <DEVICE-NAME> |
The following keyword is common to all interfaces: Optional. Displays
detailed MST configuration on a specified device
- <DEVICE-NAME> –
Specify the name of the AP, wireless controller, or service
platform.
spanning-tree |
mst |
Displays MST configuration. Use additional filters to view specific
details. |
instance <1-15> |
Optional. Displays information for a particular MST instance
- <1-15> – Specify
the instance ID from 1 - 15.
interface <INTERFACE-NAME> |
Optional. Displays MST configuration for a specific interface instance.
The options are:
- <INTERFACE-NAME>
– Displays MST configuration for a specified interface. Specify the
interface name.
on <DEVICE-NAME> |
- <DEVICE-NAME> –
platform.
nx9500-6C8809#show spanning-tree mst configuration
% MSTP Configuration Information for bridge 1 :
% Format Id : 0
% Name : My Name
% Revision Level : 0
% Digest : 0xac36177f50283cd4b83821d8ab26de62
nx9500-6C8809#
nx9500-6C8809#show spanning-tree mst detail interface ge 1
% Bridge up - Spanning Tree Disabled
% CIST Root Path Cost 0 - CIST Root Port 0 - CIST Bridge Priority 32768
% Forward Delay 15 - Hello Time 2 - Max Age 20 - Max hops 20
% 1: CIST Root Id 800000157081742e
% 1: CIST Reg Root Id 800000157081742e
% 1: CIST Bridge Id 800000157081742e
% portfast bpdu-filter disabled
% portfast bpdu-guard disabled
% portfast portfast errdisable timeout disabled
% portfast errdisable timeout interval 300 sec
% cisco interoperability not configured - Current cisco interoperability off
% ge1: Port 2001 - Id 87d1 - Role Disabled - State Forwarding
% ge1: Designated External Path Cost 0 - Internal Path Cost 0
--More--
nx9500-6C8809#
